Light on garage door opener won't turn off.
Received 0 Votes
The light on my garage door opener won't go off like it used to. I thought they were on some sort of timer for a couple minutes or so! Anybody got any ideas for me to check into?
Thanks Karen
Thanks Karen
That issue is bound to literally be soldered onto the printed circuit board inside. You probably need a new board. But if I were you I would call up the 800 number of the company and talk to someone to be sure. In all the years I have been doing maintenance, and over about 20 have openers...I have gotten many calls about many things with the garage doors/openers/remotes...but never a light staying on. (Kiss of death: Probably will happen tomorrow.)
Received 0 Votes
please see my reply about the motion sensor the answer will be the same as well i am sure the power surge did funny thing with circuit board.
Merci, Marc
Merci, Marc
Merci, Marc
Merci, Marc
Received 0 Votes
I have seen this problem before. The relay contacts were welded together. I suspect the light bulb burned out with a flash and the high current during the burnout welded the contacts.
Anyway, if you have basic electronic and soldering skills, you can easily replace the relay.
