What is a ceiling fan beam mount?
Received 0 Votes
I've got a long beam 4x6 (or 8) that I am going to hang a ceiling fan from. There is a junction box (if that's the right term) next to the beam that a flourescent light used to be attached to. I removed that (and will probably need to figure out how to get the wires over nicely with wire molding - but that's a whole different story).
Right now I'm concerned about how to attach the fan to the beam. Home Depot has got this sturdy metal box (that takes up to a 70 lb") fan. It looks like it could be used anywhere - on a beam, next to a joist. It doesn't specify being a "beam" mount. So my specific question is....
Is that what a beam mount is? Or is it a specialized product?
Also, if I do use this box - there will be a 2-3" gap from the bottom of the beam to the top of the fan's canopy. Any ideas on how to fix that? Should I just paint the mount the same color as the ceiling and hope no one notices?
Thanks!
Thanks!
Received 0 Votes
I think I may have answered my own question...but wouldn't mind clarification. A "beam" mount is NOT a an electrical junction box at all - but allows me to connect the fan directly to the beam (hence, no gap). Then I'll still need to run the wires to...wherever.
Sound about right?
Sound about right?
Received 0 Votes
Originally Posted by pcboss
Are you saying that you want to mount the fan rated box on the bottom of the beam?
If so you could install a 1/2" deep pancake box.
I'm unfamiliar with pancake boxes (or their function). Did a quick web-search on the term. Just got lots of stuff on actual pancakes. Can you advise a better search term? And are you saying a pancake box INSTEAD of the fan rated box?
Thanks!
Yes, you need an electrical box to make the splices in. The fan canopy is not enough, it must be used in conjunction withthe electrical box.
A pancake box is a electrical box that is only 1/2" deep. You can buy fan rated pancake boxes.
Try this link to see many options for fan boxes. The pancake box says steelpan box.
http://www.aifittings.com/arliprod_n.htm
Received 0 Votes
Thanks!
Looked at the steel pan - http://www.aifittings.com/whnew51.htm - seems right. Not very pretty, however. You think something like his would work also for an open beam....?
http://www.aifittings.com/n_3.htm
The pancacke box is the thinnest box you can get. The problem with the pancake is that the only way to enter the box is from the back (or top, depending on perspective). That would mean that the box would either have to overhange the edge or you would need to drill the beam.
Is the beam structural or decorative?
The advantage of the pancake is that it is generally totally enclosed by the fans canopy and not seen at all.
Received 0 Votes
