chandelier on dimmer that flickers
Received 0 Votes
My kitchen chandelier is on a dimmer switch ( a dial) and a couple days ago the lights started to flicker. The dimmer itself seems to buzz when you get close to it and also the screws holding in the plate cover feel warm. Does the dimmer need to be replaced?
Received 0 Votes
On of my clients had a similar problem - He purchased a fancy chandelier at (commercial link removed)
When it came in from Italy i noticed the wiring is different as they have a different code in Europe. I got rid of the flickering by tightening the wires that were all tight up in the canopy. Sot it has nothing to do with the dimmer - it was the fixture itself that needed the fix.
