Why are lights staying dim on one circuit?
Received 0 Votes
I replaced all plugs and switches in a house. On one circuit, the plugs work fine; however, all the lights are dim. When you turn on more than one light each light gets dimmer. What is causing this problem??
Received 0 Votes
Originally Posted by lectriclee
Are thes lights on a dimmer switch?
Did you wire them in series? Remove 1 light bulb, do the others stay on?
Received 0 Votes
So these are all different lamps/fixtures?
They all worked well before you "Fixed" them?
If yes. Then you must retrace your steps (with the power OFF)
Appears to be human error.
A Loose or poorly made connection could also do this.
And cause great trouble. Don't let it wait 'till you get a chance.
Sounds like a poor neutral connection somewhere causing in actuality an unintended series circuit evidenced by the fact that when you add additional load to the circuit, the original load seems to recieve lower voltage (evidenced by the dimming light level).
As others have recommended, go back and recheck your connections. It would be in what you did since it worked before.
