extending the ground wire
Received 0 Votes
I have undercabinet lights in my kitchen. 3 of them have not been properly grounded. The ground wire is too short to reach the light florescent light fixture. How do I extend it?
Received 0 Votes
is said wire in a box behind your cabinet or something? If it is inside an electrical box, you can extend it by simply wirenutting a section of green or bare copper wire of the same gauge to it. That is only if you are truly talking about a grounding conductor (ground) and not a grounded conductor (neutral). Please provide more info.
cheers,
jeff
cheers,
jeff
SNIX,
As someone already stated, if your are speaking of the EGC ( equipment grounding conductor ) within the undercounter luminares then you can simply wirenut to the shorter EGC ( keepig it the same AWG size ) and extending to the point of termination.
If you are talking about a wire in the wall as someone stated....it has to be in a junction box and accessible....not spliced wires in the wall...sorry not something you should do..EVER...
As stated.....if you have more details please provide them.
