outdoor wiring
Old 12-14-06, 02:28 PM
F
outdoor wiring
The wiring for my outdoor lampost needs to be lengthened approx 2-3 feet in order to install a new lampost and light. Are there any special considerations when splicing outdoor wire? Thanks--
Old 12-14-06, 04:41 PM
pcboss's Avatar
Received 210 Upvotes on 181 Posts
Will the splice be underground or will it be in the pole? Is this in underground cable or is it in conduit?
There are splice kits made rated for underground use with cable. They are called UF splices.
Old 12-14-06, 05:30 PM
F
No conduit--it's underground cable. Splice will likely be underground although it may be possible to make splice within post. Suggestions?
Many thanks!
Old 12-15-06, 03:25 AM
pcboss's Avatar
If you have UF, underground feeder cable get one of these.
http://products3.3m.com/catalog/us/en001/utilities_telecom/electrical_contractors/node_GSRDT6GXPPbe/root_GST1T4S9TCgv/vroot_GSBCDFDZ1Zge/gvel_5H4WF7FRRDgl/theme_us_electricalcontractors_3_0/command_AbcPageHandler/output_html
Old 12-15-06, 04:16 AM
F
thank you!
