controlling two fans at the same time
Old 01-10-07, 06:06 PM
W
Hi, I have two fans in a room. They are called Majorca Royal Bronze Ceiling Fan or you can view them here http://www.bellacor.com/detail.cfm?Cat=38&ItemID=109913&partid=froogle-DataFeed . Do they make a variable speed remote or wall switch that will control both fans at the same time. It will have to be rated for both fans and it cannot be a solid state speed control either (stated in instruction manual). On the fan it says .6 amps. Think you have all the info you need. I just got done trying to install two recievers on them. I just set the frequency the same for both recievers and set the transmitter(remote) to the same frequency and well it didn't happened like I planned. For some reason only one would come on and then inorder to make the other one come on I had to press the button over and over again. When I disconnected that one it would work just fine. Must be interference in there someplace. Oh well. THanks
Old 01-11-07, 05:53 PM
Received 1 Upvote on 1 Post
was that a question or a statement??????????????????
