Remote low voltage transformer
Will this work? I want to replace a kitchen island incandescent lighting circuit with a modern low voltage track system. I would like to locate the transformer about four feet from a dimmer wall switch and then use the existing thirty foot run of 14-2 with ground Romex cable between the transformer and the track? I had planned on using a 600-watt transformer. Can the transformer be concealed inside a wall if access is maintained?
Yes, you can conceal a transformer inside a wall if access is maintained. As long as "access" means that you can get to it without disturbing any of the finish of the building. But all connections must be made inside of an electrical box, so you probably need a box for your transformer.
the other thing to head up is the transformer size per nec code on low voltage side [ 12 V ] is limited to 300 watt [ 25 amps] and the 14-2 wire will not able handle this load at all
if you have 600 watt transformer you should see two " tap " there each set for 300 watts each to prevent overloading it
for very short run you can run 12-2 but i havent get into this deep with full capaity on 12 v circuit so therefore just load up to 80% full load like about 240 watts or so that is 20 amp there and it right on the limit of 12 -2 but my main condsering is the loading and heat of the wires
you may have to split the track to two or three section to prevent overloading
it is the same rules with line voltage as well
to order get the total capaitcy you have to add all the lamp wattage for each lumiaire and get the total and see how far you can spread out
that something you have to think about it
there is few other option as well but for now i just hold it back for a min until you get some idea how many lumiaires you will hang up on the track and the length of track [ it can make the diffrence because the low voltage system is pretty senstive with voltage drop ]
if more question please do drop a line
Merci , Marc
Merci , Marc
