Light Bulb for Outdoor Lamp Post?
Old 02-18-07, 09:14 PM
K
I am having trouble finding a replacement bulb for my outdoor lamp post. The bulb shows 24 V/50 W on it, but I cannot find any bulbs that match that on line or when I looked at Home Depot.
The light is on dusk to dawn if that helps. Any suggestions with a bulb that I could buy as a replacement?
Old 02-18-07, 09:30 PM
H
This sounds like an oddly shaped or sized bulb. My father has an electrical contracting company. He can get things that are harder to locate as a common consumer. I would recommend possibly talking with a local electrician in your area who might be able to help you locate the right size bulb. Another suggestion would be to consider converting your lamp post to a more commonly used type of bulb. It may end up saving you money in the long run.
Old 02-19-07, 11:01 AM
F
the other place may have this on stock is the lighting store or electrical supply centre
they can useally carry or stock oddball items
can you tell me what name brand the bulb you have ??
i can able look it up and get the source to find it
Merci , Marc
Old 02-19-07, 02:54 PM
Received 294 Votes on 253 Posts
Are there any other numbers onthe bulb? What type of base does it have?
Here's one that is 24v 50 watt.
http://www.goodmart.com/products/215733.htm
There's more on this page.
http://www.newenglandsolar.com/catalog_pages/catalog86.htm
Here's another one
http://www.lightbulbsdirect.com/page/001/CTGY/MR16-50W24V
And bunch of different ones
http://www.bulbs.com/Bulbs/20V_--_60V/40W_--_75W-/results.aspx
Google "24v 50watt bulb" and a bunch will come up.
Old 02-19-07, 06:11 PM
K
Talking
french277V There are no other markings that show who made it.
Joed, The 24V that I found had the "pins" in them as well.. then I saw your link that had the ones with the "standard screw base" and wahla, that is what I need.
Took a picture of my bulb to show you what I have:
http://s93.photobucket.com/albums/l41/KathyK_dogs/?action=view&current=100_0238.jpg
Old 02-19-07, 10:42 PM
F
i think there is one website it called bulbman
if the link is correct it is www.bulbman.com
that bulb look like marine grade or locomove bulb type
can you take a second photo but put the tape measure next to it so i can refer the size just make sure i am correct track
Merci , Marc
Old 02-20-07, 03:45 PM
K
Thanks french277V. Have a problem where the bulb broke, but I put a regular 60 watt blub beside it along with the measuring tape to see if you can tell. Looks like about 4" tall.
http://s93.photobucket.com/albums/l41/KathyK_dogs/?action=view&current=100_0247.jpg
http://s93.photobucket.com/albums/l41/KathyK_dogs/?action=view&current=100_0242.jpg
Old 02-20-07, 03:56 PM
F
http://ecom.mysylvania.com/sylvaniab2c/b2c/z_login.do;jsessionid=(J2EE4080100)ID4080150DB1633489480565115926End;saplb_*=(J2EE4080100)4080150
this is pretty long link but found one at 60 watts at 24 volt but let me search some more
Merci , Marc
Old 02-20-07, 04:19 PM
K
Amazing, that this is so hard to find! This bulb has been in place for about 6 years, so hopefully I can buy one more and move before the next replacement - or, buy 2 when I find it so I have a backup just in case.
Thank you so much for helping me find this type of bulb!
