Hard wiring under cabinet lights
Old 05-01-07, 11:08 AM
T
Hello
Thanks in advance for any ideas on the following
My aim is to install under counter puck lights via hard wiring, and if possible, no transformer (use 120v pucks).
I am installing under cabinet lights in my kitchen. To save running romex all through the 3 kitchen walls involved, I am going to replace 3 existing single gang counter top receptacles with 3 x 2 gang old work electrical boxes. I will put dimmers in the extra gangs. (I got that idea from "This old house")
Once that is done, I can run 30" of new romex behind the wall up to the bottom of my cabinets.
Here is my problem.
I definately want to avoid installing more receptacles under my cabinets (that eliminates me using any kind of plug in fixture)
If at all possible I would also like to avoid mounting a transformer, so I think that eliminates low voltage puck lights.
Are there any line voltage puck lights I can "daisy chain" together ( I need 3 in a chain) and then hard wire straight onto the romex that will be hanging out of the wall under my cabinets? And if so, what is the appropriate junction box to use?
I haver seen the fluorescent hard wire fixtures on the web, but was hoping to find pucks I could hard wire.
If necessary I would go with low voltage pucks, and install a transformer, but I need an elctronic transformer that can be hard wired onto the romex.
Thanks to those of you that read this book!
Tony
Old 05-01-07, 11:18 AM
R
No can do. In the US you cannot connect lights to the counter top receptacle circuits. You need to run a new circuit, or use an existing non-counter top circuit.
Old 05-01-07, 01:59 PM
T
Wow!
I got the idea from "this old house"
http://www.thisoldhouse.com/toh/print/0,17071,1032113,00.html
I don't understand why all the under cabinet light fixtures with plugs attached, can be plugged into counter top receptacles .
Sorry for second guessing you.
Old 05-01-07, 02:12 PM
R
The NEC does not allow lights to be on the same circuit as the counter top receptacles. Period. No exceptions.
The installation directions you found are a code violation. This Old House should be ashamed of themselves.
Old 05-01-07, 02:20 PM
T
I just called the state inspectors office, you are 100 percent correct! Thank you very much for saving me a lot of trouble.
Tony
edit: I think the plug in type lights are acceptable because they are considered temporary. (to answer my own question!)
Old 05-01-07, 02:27 PM
R
Yes, you can install lights that have a cord and plug and plug them in. You just are not allowed to hard wire lights to those circuits.
Old 05-01-07, 02:29 PM
T
Thanks Racraft
One last question if I may.
Currently the receptacles are located 5" below the bottom of my cabinets. In order to hide the plugs on the plug in fixtures I will now go with, can I raise those receptacle boxes to within 1" or 2" of the bottom of my cabinets? Or is that a code violation?
Thanks
Tony
Old 05-01-07, 02:33 PM
R
The receptacles need to be within 20 inches from the counter top surface.
Old 05-01-07, 02:39 PM
T
well that's great.
Even if I raise them the full five inches, so they are snug underneath the cabinets, they will still only be 17" above the counter.
In this way I can completely conceal the plug.
Thanks
Old 05-01-07, 02:43 PM
R
I would leave your existing receptacles in place and add new ones where you need them.
Actually, I would use the hard wired lights and power them from a different circuit, but you seem reluctant to do this.
Old 05-01-07, 02:49 PM
T
well I have a dedicated dishwasher circuit and a dedicated waste disposal (20 amp each). Could I tap into either of those?
If the answer is no, I presume I would need to run cable from the light switch. That would mean running cable accross the ceiling, and a lot of drilling through wall studs of course.
Old 05-01-07, 02:51 PM
R
No, you don't want to tap those circuits. What about a new circuit from the main panel?
Old 05-01-07, 02:54 PM
T
Ha!
Looks like it's time for a professsional!
Thanks again.
