Ceiling Fan Not Balanced on High
Hello,
We just moved into a different house and when I turned the ceiling fan on low wverything is great. However, when I try the higher settings, the fan wobbles quite a bit. It is like it is not balanced. Is there anything I can do to correct this? It is a very nice fan.
Thanks,
Hick83
Thanks,
Hick83
Make sure that all the hardware connections are tight.
Is the mounting bracket secure to the ceiling box? Is it on a long drop rod? Is it correctly installed?
If you make sure of the items listed in pcboss' post, then you can purchase a balancing kit and follow the directions in the package. You will have to do it trial and error.
