sorting MR16s via Resitance Measurement?
Old 05-12-07, 11:22 AM
I have a bunch of MR16 bulbs. Some are 20W and some are 50W but the markings are unreadable. Can I sort them by taking a resistance measurement across the pins?
What reading should I expect for each?
Thanks,
David
Old 05-12-07, 12:42 PM
Received 236 Votes on 207 Posts
Might work. I never tried it. You would need one of each of the know wattage to compare to the ones you have.
Old 05-12-07, 12:51 PM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
if these are 12 volt lamps (which I believe most mr16's are but they are also available in other voltages)
20 watt=7.2 ohm
50 watt=2.88 ohm
