ceiling fan ground wire?
Old 05-28-07, 05:39 PM
Question ceiling fan ground wire?
Im putting a ceiling fan and light fixture in to my parents house, when i took the old light fixture off i noticed that the ground wire is bare copper wire. The ceiling fan requires a green wire. i just wanted to know if i can add a new ground wire and how would i do this? Thank you.
Old 05-28-07, 05:55 PM
R
The ground wire in most houses is bare copper. Your fan wants a ground. It makes no difference whether the ground wire in ceiling is bare or green.
Old 05-28-07, 10:52 PM
Well the ground copper wire is inserted in to each of the other wires, (white & black) then it just touches the metal outlet box is this safe, how would i be able to fix this. If possible i would like to add a new ground if called for. thanks
Old 05-29-07, 04:42 AM
R
The metal box is supposed to be grounded.
Everything you have described sounds correct.
