Smoke from fan
Old 05-30-07, 03:53 AM
Received 1 Vote on 1 Post
Question Smoke from fan
Daughter turned ceiling fan/light on yesterday and noticed a spark and a bit of smoke. Fan and light still work. Do the spark and smoke indicate immediate replacement of the fan?
Old 05-30-07, 06:22 AM
Received 237 Votes on 208 Posts
Smoke is not good. I would not use the fan until you determine the source of the smoke.
Could be the fan speed control capacitor.
Old 05-30-07, 06:32 AM
Depends on the amount of spark and smoke. Could the smoke have been just some dust instead? If real smoke, was it a very tiny amount? Sparks happen all the time in electrical stuff. Tiny sparks usually aren't much of a problem. Larger sparks are.
I would continue to monitor the fan for a while. But to be safe, don't leave it running unattended.
Old 05-31-07, 03:15 AM
Thanks to both of you. Small spark, tiny puff of smoke and daughter said it happened again this morning. The fan will be off until I get a chance to look at it. Was thinking of taking the fan down and checking to see if there are loose wires. I hate to just replace the whole thing if I don't need to. On the other hand, installing a new fan is preferrable to a fire.
