Gas Pipe near recessed lighting
Received 0 Votes
I cut holes for some recessed lighting in my ceiling. The lights are 6" cans and are IC for sitting directly against insulation. The problem is I noticed pretty much exactly on the can hole edge is some copper colored piping probably leading from the furnace in the attic to the adjoining kitchen. I can't slide the hole over because of a joist so I am stuck placing the can directly against this copper colored tubing which is at about 1/2 way up the can height.
The question is this- Is this a fire/electrical/gas hazard? My guess is that since the can is IC rated and can sit against insulation it doesnt get hot enough to start a fire so it shoudn't be an issue. The electrical housing for the can is contained in a closed box as can be slid away from the tubing at least 8"-12" or so....
Any thoughts?
Any thoughts?
I highly doubt it's a gas line, specially copper.
It may be one of your refrigerant lines going from your a/c compressor to your indoor unit or just a simply water line.
You should be fine.
You should be fine.
