wiring squirrel cage motor
Old 09-23-07, 09:29 AM
I've got a small squirrel cage motor 115 volts, 60 hz with 4 wires coming out, not just 2. The wires are RED and BLACK, and WHITE and BLACK.When I try to hook up various combinations of wires to house current the motor either doesn't do anything or it hums. While it's humming, if I start the shaft spinning, it will continue to spin under power, though it doesn't seem to have a lot of power. How do I hook it up to work? I have a small file pic if I could attach it to this question. Thanks for any help.
simonmeridew
Old 09-23-07, 07:45 PM
chandler's Avatar
Received 2 Votes on 2 Posts
It sounds as if you are missing the capacitor, which will tell the motor which way to turn.
Old 09-23-07, 09:27 PM
GregH's Avatar
Super Moderator
Received 15 Votes on 15 Posts
To show a picture you need to upload it to a free photo host like Photo Bucket and provide a link or code it using the controls above the reply box.
Old 09-24-07, 06:58 PM
Thanks for the replies: I don't know for sure but I don't think it's a capacitor start motor. Here's a pic of the motor:
http://hotimg8.fotki.com/p/a/4_157/1...-web-motor.jpg
simonmeridew
Old 09-24-07, 08:43 PM
That motor is surely a capacitor run motor.
Old 09-25-07, 08:32 AM
Received 96 Votes on 88 Posts
Is there a name plate on the motor? Post all the info from the plate.
Old 09-25-07, 04:08 PM
GregH's Avatar
Super Moderator
If it is an oem motor you likely will not be able to get a wiring diagram from the motor manufacturer.........[Been there done that...... lots!]
What you need to do find out exactly what it came from and use their diagram.
Old 09-25-07, 05:34 PM
My friend who is admittedly electrically challenged asked me to find out how to hook it up. It was the ventilator fan for a friend's photo processing machine, and that guy took it out without paying a lot of attention(none in fact) how it was wired up. So slim to none chances on getting a wiring diagram. The plate says 2.5 amps, a Kusatsu motor. I guess I can't go to Japan for the particulars. Thanks anyway for reading my posts and trying to help.
simonmeridew
Old 09-25-07, 06:45 PM
chandler's Avatar
It looks similar to this one: http://cgi.ebay.com/NORITSU-FAN-WITH...QQcmdZViewItem It may give you a starting point, like asking the seller where all the wires go, as if you were going to buy it.
