Wiring a ceiling fan
Old 10-08-07, 11:53 AM
I am trying to hang a Casablanca ceiling fan with an intelli-touch control. The fan has a black, white and green wire. The ceiling has a black, white, green and red wire. The wall has 3 black, 3 white and a red wire. The control has a black, black w/white stripe, blue and black w/white stripe hooked together and a capped black wire. What gets hooked to what?
Old 10-08-07, 12:05 PM
R
What do the directions that came with the controller and.or the fan indicate?
Old 10-08-07, 12:08 PM
It says black to black and black w/ white stripe to black.
Old 10-08-07, 12:16 PM
R
It must tell you more than that.
What is the wiring at the switch? Does this controller replace the switch? If not, what do you want the switch to do?
Old 10-08-07, 12:50 PM
I got it working now. I had both red and black hooked at the ceiling and I only needed the red hooked up.
Old 10-08-07, 12:52 PM
R
The black wire in the ceiling is most likely always hot. That would be typical wiring. Had you told us the wiring at the switch I would have told you that in the first place. Always provide detailed information.
I'm glad it's working.
