Fluorescent light
Received 0 Votes
Fluorescent light
I am trying to fix kitchen light under kitchen cabinet. It is a starter-type fluorescent straight tube light. The bulb burned out so I bought a new bulb. It didn't work. Then I bought a new starter but it still didn't work. So I bought a new ballast but before I try replacing the old ballast, I want to ask a question.
Here's what my old ballast has imprinted on it:
CAT B2
For 14-15-20-22 LAMP
35 AMP 118V 60HZ
Listed Ballast
This is what the new ballast has imprinted on it:
CAT LC-14-20-C
14, 115, 18, 20W LMP
STRAIGHT TUBE ONLY
120V 60HZ 360 MA
704G-Listed AN130
I removed the metal cover over the wiring trough and there is a sticker that says:
CAUTION
Do not use on a supply circuit of more than 118 volts.
So here's my question:
Is it safe to use the new ballast even though it says 120V or should I try to find one that says 118V?
CAT B2
35 AMP 118V 60HZ
Listed Ballast
CAT LC-14-20-C
STRAIGHT TUBE ONLY
120V 60HZ 360 MA
704G-Listed AN130
CAUTION
