Loose light bulbs?
Old 12-01-07, 09:21 PM
N
Loose light bulbs?
I'm wondering what would cause a light bulb to become loose on a regular basis. I'm talking about perhaps once a month having to screw it in tighter because it's flickering. We're in an apartment building that probably has older wiring.
Old 12-01-07, 10:02 PM
core's Avatar
I'm guessing it's just that the threads in the fixture have become malformed/widened over the years, thus not holding the bulb securely in place. Each time the bulb heats up and cools down it could work itself loose I suppose.
The fixture could probably use replacing if your landlord will do so. Otherwise try a CFL bulb which generates less heat.
The contact in the fixture could also be dirty.
