Cutting hole in plaster ceiling for outlet
Received 0 Votes
Hello,
I have a small lightweight flourescent ceiling light to install in a plaster ceiling (house from 1954). I have a round blue plastic fixture box for the electrical. The wiring is in place and ready to go. My question is: can I use a hole saw on plaster without destroying the ceiling? also...what size hole saw (I have a set of them)?
Many thanks,
Majac777
Many thanks,
Majac777
I use a 4 1/4" hole saw on my drill to cut for round boxes. Make sure you aren't cutting directly into a joist, or into plumbing/electrical, etc when you make your cut. You could possibly cut it with a sheetrock saw, but the hole saw in a drill takes a nano second by comparison, and it is neat looking. Also, figure out how you will be supporting this fixture, if by a spanner box or with lumber.
