If new 100 watt bulb burns out immediately...
Old 12-17-07, 08:14 PM
...could it be because fixture only takes 60 watts? Or is there more likely to be a short in the fixture?
Old 12-18-07, 03:41 AM
O
It's more likely that it's wired wrong and getting 220 volts.
Is it a recently wired light fixture?
Old 12-18-07, 04:18 AM
R
The maximum wattage of a fixture has nothing to do with whether or not bulbs will burn out, but has everything to do with how hot the fixture gets and with the wires the ficture uses.
Somehow you are getting too high a voltage for the light.
Old 12-18-07, 02:40 PM
R
Received 1 Vote on 1 Post
To add to oneofamill's and racraft's posts: You should not be using a 100 watt bulb in a fixture with a maximum rating of 60 watts. The 100 watt lamp will generate too much heat and could easily damage the fixture and possibly start a fire.
Have you always used 100 watt bulbs with the same fixture and it suddenly started blowing up new bulbs? Heat may have damaged the fixture -- or the wires in the box -- and caused the over-voltage condition. You'd have to pull the fixture and inspect the wiring.
One thing to be aware of: If the light is on the same circuit with receptacles or other lights, there is a good chance that there is too much voltage on the entire circuit.
Old 12-18-07, 07:24 PM
Depends on what you mean by "immediately". Is it one millisecond? One second? Ten seconds? One minute? Ten minutes? One hour? One day? One week?
If it really is immediately, which I would call one millisecond, then the cause is probably very high voltage. Or it could be a bulb that was damaged before you put it in.
