Three-way switch replacement in lamp
Received 0 Votes
I replaced a three-way switch in a table lamp that had one that would not turn over the weekend. When I tested it, the switch turns fine and steps up with each turn of the switch but the light flickers and I hear a faint crackling sound from the bulb. It not a fluke because this has happened to me with another lamp.
It is just two wires connected to the switches screw terminals. What did I do wrong or what should I look for? Thanks.
I bought the cheapest 3-way bulbs I could find and they did the same thing. They don't seem to fit into the socket properly. Since I replaced them with name brands they've been working fine.
Received 0 Votes
check screw terminals
When you hooked the lamp back up did you make sure that you have a good connection under the screw terminal with the wire? Whether it is aluminum or copper make sure that you have a good tight connection. Tug on the wire after you tighten the screw to make sure it is not loose. The lamp should not be the problem.b
Received 0 Votes
Received 0 Votes
After not being able to solve it in the previous table lamps, I just bought new lamps. I know... an expensive solution. That is why I was surprised to have the same issue after change the 3-way switch on the new lamp.
If it does is again, I will let you know.
Perhaps I shouldn't be surprised as the project started of by losing a new switch still in it's package... a victim of chewing by our one year old puppy... the same dog that prefers the metal end when chewing pencils. Bad dog!
