Can light recommendation for unfnished basement
I'm making plans to lightly finish my basement. No sheetrock, just painted floors, walls, ceilings, and a few partition walls.
I went to the local Lowes to check out prices on can lights and was floored by all the options. I brought home a shallow 6" can made by Juno because I thought mounting them a bit highter in the joist, might make for a better look. But they are $18/each... I don't know if I really need to spend that much. They have some for $6. I'd rather spend less! It seems the only advantage might be that I can get a little brouder pattern of light by mounting them heigher in the joists.
My questions are;
Do I have have to IC rated cans? I won't have any insulation in there, but it will be mounted close to the sub-flor. How close to the subfloor above can it be mounted?
Also, I'm thinking about painting the fixtures when I spray the entire ceiling. Any problems with that?
My questions are;
I like that term "lightly finish the basement" because I had BIG plans to finish our basement but I might consider only painting, new lighting, and leaving the ceiling unfinished.
..I would check the company if you can paint them as well.
