dining room lightning no longer centered over table
Received 0 Votes
Hello
I'm wanting to change out my late 70s - early 80s dining room chandelier lighting to a more modern lightning but here's the problem. I am redoing all cabinets in the kitchen and re positioning them so that they protrude into the dining room about 6+ inches thus moving the table from under the light. Any ideas on how to bring the light back over the center of the table without having to cut a new hole in my sheetrock? I was thinking of some sort of track lightning.
(Edit in) I forgot to include that this light is on a dimer switch.
Thanks
Randy
Thanks
Randy
Received 0 Votes
Three options come to mind..
Option 1: install a swag chain, put a hook in the ceiling where you want the light to hang, connect the light where it has always been and drape it over to the hook.
Option 2: they make a decorative cover that mounts to the ceiling that is about 12" in diameter, that's wide enough to cover your old box hole and install a new box where you want one. You can fill in the old box hole and who cares what it looks like since it will be covered, or for that matter put a cover plate over it then mount the decorative plate. these are available in all lighting shops and probably the Home Depot types too.
Option 3: mud up the hole, re-texture, install a new box
Track lighting is OK, I have it in my kitchen soon to be removed... It's too directional and you never have light everywhere.
Randy, make sure you have enough lead in your cable before you begin your box move. If you have my luck, it will be at the end of the run in the wrong direction. Hopefully you will have enough slack to make the move. The reason for mentioning this, is you can't permanently cover up a junction box, with one of those big uh-oh covers that look like they came from a castle in the 1400's. Do you have access from above? If not, you may be able to install one of the spanner bar type ceiling fan brackets from below in a new hole, feed your cable into it, and patch the other hole. Good luck with the install.
Received 0 Votes
Chandler.....excellent point and one that I forgot about! You can never have a junction box that you can't access, ie cover it up with one of those 12" decorative covers! The same scenariojwould still work, just patch the hole where the box was and the cover covers a multitute of plaster patching sins!
