leoeal
leoeal
Hi I am rewiring my cottage with the help of a qualified
electrician,there is no plaster on the walls .What I want to do is
put a separate circuit with switches for table lamps the way
they switch them on the telly or the movies I still want the
normal lighting on the ceilings wall lights etc with switches
I understand that the sparky might know but just in case it
will save time if I have the info I don't know if it would need
a separate fused outlet for that circuit .HELP PLEASE!!!!!
Nothing special is needed. This is a common installation. It is done all the time in rooms with no overhead light fixture. The only thing you will need to decide is if you want both outlets on the the receptacles switched or only one of them. It is simple to do it either way.
