is a hallway ceiling fan worth it?
Received 0 Votes
We have a 2 story townhouse, and being one zone for AC/heat, the upstairs is always hotter than downstairs.
Would it help to install a hallway ceiling fan above the stairs? There is a light figure already there, directly above the stairs, but the ceiling fan would be a couple feet over, in the center of the upstairs landing.
Any thoughts?
Any thoughts?
I have seen them installed just for that purpose, but mind the width of the fan. Your hallway may be less than 48" wide. Now, they make a "turbo" type fan that really moves alot of air, and have installed them in small areas as laundry areas, etc, due to the limited space. They really don't have "blades", but three tightly twisted wings to move the air.
Received 0 Votes
We have a large landing at the top of the stairs, so that isnt a problem.
I would have to run the fan on 'reverse' directions as the other fans on the second floor though, wouldn't I?
In the summer, reverse to pull the cold air up from the floor below, and in the rooms, forward, to push it down onto the room? Otherwise, wouldn't it just keep the cold air on the lower level?
Received 0 Votes
Fan has been on for 7 years
I put in one of these for exactly this purpose. It has run continuously except for an occasional dusting and it does
work. It keeps my thermostat from kicking on so much in the winter.
In a previous home where we rarely used the upstairs I actually made a door over the stairwell. That really works but doesn't look so great.
good luck
good luck
