Did I do this correctly? Grounding Wire/Screw Question
I replaced my vanity lighting fixture.
I had 3-wire coming out of the wall
1. Black
2. White
3. Copper
The light fixture has 3-wires
1. Black
2. White
3. Copper
I attached the black to the black, the white to the white and the copper to the copper and secured with the orange plastic covers (don't know what you call these..)
The light turns on and off just fine.
Now here's my question...
I did not wrap the grounding wire around the green screw on the vanity bracket. I attached the grounding wire to the copper wire coming out the of wall...
Is this correct?
1. Black
2. White
3. Copper
1. Black
2. White
3. Copper
Is this correct?
But you lost me on "ground wire jumper connected to the box ground screw".
I don't see any box.
When I took down the old vanity light, there were only 3-wires coming out of the hole in the wall.
I'm confused...Sorry, but this ithe first time I've done anything like this...
If this helps, I just exactly this : http://www.youtube.com/watch?v=N2x9QFAPM9k
WITH THE EXCEPTION THAT I DID NOT WRAP ANYTHING AROND THE GREEN SCREW.
Received 0 Votes
Wirepuller may have misunderstood your setup. Or maybe the metal box he was referring to is the fixture chassis.
But I don't quite understand the following:
The fixture should provide a place to connect the grounding wire. As long as you connect the grounding wire there, then you are okay. In general, however, grounding wires should be attached to green screws. Please clarify your quote above.
Thank you John.
Okay...let me try to clarify.
I took down the old vanity light fixture and removed the bracket.
3-wires were coming out of the hole in the wall - 1-black, 1-white, 1-copper.
The new light fixture has 3-wires bundles attached to it - 1-black, 1-white, 1-copper (this is a single wire).
After attaching the new bracket to the wall (this bracket has the green groud screw on it), I attached the vanity wires to the wires coming from the wall
black to black
white to white
coppper to copper
Then I fastening the new light fixture to the mounting bracket. This took FOREVER and was not an easy installation.
The turned the power breaker back on and tested the light - it works!
Now I question if I should have wrapped one of the copper wires around the green screw before attaching it to the other copper wire.
I followed the instructions on the youtube Home Depot video but now looking at it, it seems that the copper wire from the wall is wrapped around the screw and then attached the light fixture copper wire.
I hope this is a bit clearer...
THANK YOU!!!
black to black
white to white
coppper to copper
THANK YOU!!!
Received 0 Votes
Received 0 Votes
ground wires
you ok any ways all the ground are together (2) 1 from wall 1 from light that makes all continuos. wire from wall to wire to light and screws from light base(CANOPI) to box in the wall complete circuit. if u did not use screw maybe was a nut either way works to complety the path. u ok u ok... keep it up. hex
