Ceiling Fan Strange behaviour, experts only
I recently moved the electrical controls for my ceiling fan which resulted in some temporary problems. I have an ON/OFF switch to control the fan and a dimmer to control the lights. Three wires going to the ceiling. Red - Fan, Black - lights, White - nuetral. To extend the controls I added a J-box, same wire in and out, all connected wires match color for color. At the controls, Red wire to load side of switch, Black wire to load side of dimmer. White goes to Nuetral. !20vac power to line side of switch and dimmer. When I started the fan for the first time after renovation, I turned on the fan switch. I was surprised to see fan ON, lights Full ON. Both fan and lights operated with switch. Dimmer did nothing. I thought I had shorted Red and Black together but then dimmer switch should also have activated something. I checked wiring - all OK, no sign of clamps cutting sheath on wires, all wires correct location. After a few tries on the switch, both controls operated properly and still do, no changes to any wiring. The ceiling fan is about 15yrs old. would it have an electronic module that determines fan/light function giving problems?
It's probably an electronic dimmer? Once the circuits all reset correctly, it worked.
If it's working now, who cares? If it starts acting up later, then maybe it will need replacement. Electronics are funny that way.
