Fan Won't Balance
Old 08-25-08, 04:09 PM
Fan Won't Balance
I have a fan that just won't balance and getting loud. I've used a balancing kit and messed with it for a long time and am having no luck. What could cause it to be so difficult to balance. Any tips on advanced balance techniques? Or do I just need to get a new fan?
Old 08-25-08, 04:58 PM
You can take off all the weights and then take a measuring tape and measure from the ceiling to the tip of one fan blade. Then rotate the blades by hand. See if each blade is the same distance from the ceiling. You most likely have a bent blade iron. Also check to see that you don't have a "twisted" blade.
If it still won't work look at these <a href="http://www.rlights.com/viewcategory.php?id=4&st=sbt">Ceiling Fans</a>
