Replace Pendant light glass?
Old 01-11-09, 06:08 PM
X
I have a pendant light in the dining room that has the glass broken. Is it possible to replace the glass or does the whole thing need to be replaced? Here's link to a picture with a similar fitting. Thanks.
Royce Lighting at Lowe's: 1-Light Peuvian Bronze Pendant
Old 01-11-09, 06:28 PM
pcboss's Avatar
Received 69 Votes on 59 Posts
Often times the glass can be replaced. Take a measurement of where the glass mounts so you can get one that is the correct size. Big box stores have repalcement part available.
Old 01-11-09, 06:54 PM
X
Thanks. Do you know how these are held together? Are they twist fittings or something else? It's tough applying too much pressure as the glass is broken already.
Old 01-11-09, 07:45 PM
pcboss's Avatar
Look where the metal meets the glass. Sometimes there are 3 screws above the glass that screw down to hold a lip on the top of the glass. You may also have a screw on nut under the glass that hold the glass up on the socket.
Old 01-11-09, 09:14 PM
X
Thanks for the help. Hopefully i can now take it apart.
Old 01-11-09, 09:28 PM
T
If Lowe's does not have the replacement glass shade, you can contact Royce Lighting direct at www.roycelighting.com by clicking the Contact Us button.
