Ceiling Fan Rotation
Received 0 Votes
We have a two-story, vaulted ceiling in our living room. There is an open family room on the second floor. We are installing a ceiling fan in the living room and are not sure if we need to have the fan blowing up or down in the winter.
Received 0 Votes
Generally fans blow down in winter to take the rising heat from the ceiling and bring it back down to the lower level.In your case the only issue is if you're trying to bring heat to the upper room.If so then it would be a question of house design as if the uppewr room was not located close enough to the down force to gather heat it might be better to run the fan drawing upwards.Bottm line is it sounds like an experiment is in order to determine which is best for your house.
Far be it for me to disagree, but I have found that running the fan in reverse will tend to bring the cooler air from the floor and wash the walls with the warmer air. But as spdavid said, it is probably going to be a test situation to see what works best for you.
Received 0 Votes
Convention wisdom says up in winter and down in summer. Note that both directions will bring the warm air at the ceiling down, but having the fan blow up brings it down along the walls and having the fan blow down brings it down in the middle of the room.
But, conventional wisdom is not always right. It depends on the shape and size of the room and personal taste. You must experiment to determine what is right for you.
Just as one data point, what is right for me is neither. I strongly prefer not to run the fan at all in either direction in the winter.
