What have I done wrong?
Old 03-12-09, 09:34 PM
Yesterday I installed one light fixture, it works great.
Today I did a second one in the same manner but something is wrong. The major difference with that the new fixture is that instead of 6 wires (3 pairs) there are 3 individual wires for it to connect to. This difference still allowed the original fixture to work fine.
I made a couple ofchanges to try and fix it, however they may also now be the problem.
1- wrapped some copper wire around the wires to get some better contact
2. screwed the panel onto that metal tongue extra tight, managed to move the tongue about an inch clockwise
Does the order of the wires matter? Should I reposition that tongue/prong thing?
When you turn the lights back on after fiddling with them they flicker on for a second and then the power goes out
Old 03-13-09, 07:46 AM
Tolyn Ironhand's Avatar
Received 711 Upvotes on 604 Posts
Again, we are in the US, yours may be different:
When you say you lose power do you mean it just stops workig or does it trip a breaker or blow a fuse?
Since your wiring system is 240 volt (I think) you should have 2 colored wires and then a bare or green wire. From what you are describing the bare/green should go the the same lug as the metal tongue. The other two wires go to the other two connections. It should not make any difference which way they are wired.
Make sure you strip a little insulation from the wire to make good contact to the wire.
Some of them fancy pictures would be helpful too!
Old 03-13-09, 06:56 PM
Tried it and it fixed the problem! Didn't even need a storybook !
Thanks
