HELP!! - Light Dimmer Problem - Hunter Fan w/ Hampton Bay Remote
Old 04-25-09, 11:09 PM
A
Question HELP!! - Light Dimmer Problem - Hunter Fan w/ Hampton Bay Remote
Hello,
I have recently bought a Hampton Bay Remote with Wall Switch, I have installed it to a Hunter Ceiling Fan. The problem is that I cannot seem to get the light dimmer to work.
The multi speed on the fan works fine. Here is a diagram of how I hooked it up. I would like to get the dimmer to the light to work and im sure its simple for someone who is an electrician. Any help is appreciated.
Thanks,
Andrew Duclos
andrew.duclos@gmail.com
Old 04-26-09, 07:13 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
The simple answer is you need to take the blue wire from the receiver and connect to what I belive is the black/white of the fan. (If that is the wire that is going to the light kit of the fan)
The red wire should not be going to the blue wire on the receiver. The blue wire is the "output" to the light.
Old 04-26-09, 10:52 AM
A
Thanks!
That did it here is the new diagram and it works like a charm.. Thank you TolynBeer 4U2.
Here is the updated diagram
-Andy
Old 04-26-09, 12:07 PM
No problem! Happy to help.
BTW - It REALLY helped that you had such a good diagram. Well done on your end! Beer 4U2
