Fluorescent Lights Will Not Work
Received 0 Votes
My house is almost 6 years old and I have a fluorescent light fixture(T12, 2 tubes, 48 inches) in my garage ceiling that recently will not work. I thought maybe the fluorescent lights needed changing and so I replaced them. It worked for a a day or two and now it doesn't work at all. After replacing the old tubes and I first turned the switch on, I could see a small dimmer of light that flicked on at the end of the tube but now it doesn't do it at all. Is it the ballast? the starter? should I replace the whole unit?
Replace the starter if there is one. It may be as cheap or cheaper to replace the light rather then the ballast. No real DIY way to check the ballast. If though you see "tar" oozing out odds are it is bad. Of course first you need to check the hot and neutral to make sure it is getting power..
Received 0 Votes
Bad ballasts also can give off a "burnt honey" smell.
In case you don't know this:a starter looks like a C-cell battery,a small usually aluminum but sometimes plastic cylinder.Twist about a quarter turn to remove.50/50 chance yours has one,the older the unit the more likely it does.
Agree that in many cases especially if you value your time and trouble it's just as well to replace the fixture as the ballast.
If the house is only 6 years old, unless the fixture was used, it will not have a starter.
Are you sure the bulbs are seated in the sockets? Did you replace both of the bulbs?
Received 0 Votes
Yes I did! I just finished replacing the whole fixture and of course that corrected the problem but now I think there is something wrong with my wall switch. After flipping it on many times the light will come on but there are a few times when I flip the switch, it does not come on. I guess I have to replace the switch ?????
Received 0 Votes
Try to wipes the bulb with glass cleaner and put it back up it should go.
If not then you need to look more deeper due you may have grounding issue along the way with luminarie.
If that was a cheap shop or cheap strip fixure you need to be carefull some are pretty picky with bulbs espcally with wattsaver verison they are hard on ballast.
Merci,Marc
Merci,Marc
