Ceiling Fan Not Pushing Much Air
Received 0 Votes
Ok I don't know what model it is but its from around 1990s I believe. Its not giving out much air on high and it takes a while to start up especially on low and medium. All my other fans run a lot faster and push 4-6x more air. Anything I can do to fix it?
Heres a picture of the top of the fan, I don't know what manufacture and model it is.
Also heres a video of the fan running. [Take a look @ 1:35 on how slow it starts in low]
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/XhKtwxSSA4c&hl=en&fs=1&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/XhKtwxSSA4c&hl=en&fs=1&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
You have one major issue allready show up on the Youtube photo as I look at it.
The zip cord is not allowed for perment usage.
Is that Zip cord used for fan ? or have one circuit for the light and other ?
You should have that running good in high speed if connected correct.
Is that juction box was used for ceiling light before ?
Let us know then we will go from there.
Merci,Marc
Merci,Marc
While we await your answers. Motors should not be started in the lower speeds.
Airlfow is a function of blade speed and pitch. If the blades have very little tilt they cannot move much air.
Received 0 Votes
Merci,Marc
Merci,Marc
also the junction box was not used for a light before its rated for fans.
I started the motor in slow speed after i started it in high speed just to show how slowly it starts, most of my other fans even on low start much faster. And if i make a higher blade pitch the fan moves even slower on high so not much more air is pushed since it gets really slow.
Your fan should not be wired with speaker cable or zip cord which looks like the cord on a lamp. You would need to use a method suitable for permanent wiring like non-metallic cable or metal clad cable.
Different fans run at different speeds. Brand A's low could be noticeably faster than a Brand B fan.
The blade pitch is set by the blade holders. Trying to change the pitch yourself will only ruin the holders.
Received 0 Votes
So I'm guessing just leave the fan alone but replace the wiring.
And as another thought, do the blades turn clockwise or counter clockwise as you look at it from the floor. Maybe you need to flip the reverse switch, which should be somewhere on the housing. Clockwise pushes air down for summer use. Counter clockwise pulls the air up and gives a more gentle flow for winter.
Received 0 Votes
idk maybe its because of the blades are bend they seem to be hanging lower on the end of the blades and its not the metal holders or the screws being loose either cuz i checked that
