Utilitech recessed lighting problem
Received 0 Votes
I recently Bought and installed 3inch Utilitech recessed lights (Item #: 244196 Model: 105849-014 @ lowes). Since the install the lights all work fine for about 10 min, then one of the four will shut off, then the thrid one will shut off (while the first one comes back on). Its like a musical chairs for lights. I kind of like it, but my wife doesnt.
Does anyone have any ideas of what I can do? Should i just try and re-wire the whole thing again? Or is this a common problem with this model.
Welcome to the forums! According to the specs, a maximum wattage bulb is 50 watts. Have you exceeded that? These cans are Non-IC cans (Non insulation contact), so if you have insulation or minimal space above the cans where the air is blocked from them, they will react that way. It is the thermal overload switch doing its job.
