No air from the ceiling fan!!!!!!
Received 0 Votes
I have a ceiling fan in the kitchen that was already there when we recently bought our house. The switch is in the right position (fan is going clockwise) & the blades appear too be all slanted like they should be, but you feel no air coming from it?? What's the problem?
Welcome to the forums! Clockwise is a perception. Are you looking up at it? If so, clockwise is reverse and the air is moving up. CCW and the air will move downward.
Received 0 Votes
still confused??
thanx 4 the reply, but unfornuately I'm stil s.o.l. I've tried it both ways & still not feelin air from it, so if u no of any further input, I'ld appreciate it, if not thanx 4 the help!
Is it a hugger fan? They move less air, because there is less space above the fan for it to gather air to move. If it is a 4 blade, less than 40 inches in diameter, then double whammy. If you want air movement, buy a fan with Gossamer blades. A friend installed one on his porch and even with a 10" down rod, when he puts it on high it sucks and rattles the vinyl soffit used for the ceiling.
It make a big difference how fast it turns, how big the blades are and how much pitch they have. It can also make a difference how close to the ceiling it is mounted.
Unfortunately some fans are poorly designed and just don't do a very good job even when properly sized and installed. They are more or less decorative.
Hey, Gunguy, you do get around, doncha? A little out of my specialty, but back in the early 70's I was odd-jobbing hanging the Hong-Kong made 3-metal-blade 36/48/56" with upturned tips for friends and neighbors. From the supplier they came with a 6' downrod so you could cut it to length. I encountered varying ceiling heights, so I had varying down-rod lengths.
I found that around 16" air flow would begin to choke, and at 12" (the minimum) the smaller fans were really choked.
BTW, what's a Gossomer blade?
rstripe...I'm everywhere...if I have any knowledge or input..I post. Thats what happens when you retire at 50.
I kinda wondered about the Gossamer thing too.....I think they may be the real wide fabric type?
The gossamer blades have a radical twist to them, and some even have kinnard like ends flipped up. Some only have 3 blades, as that is all you need to move a lot of air. GG, time for a road trip to the big box. I think they have one hanging.
Wonder if Hunter still makes their "Original" ---big wide-diameter motor in cast-iron housing...used a spiral-grooved shaft to lubricate the bearings from an oil reservoir. The owner was supposed to remember to check the oil level every 5 years with a pipecleaner. Put a couple in in 1980, finally had to add some oil last year.
Received 0 Votes
ya its a hugger fan & a 4 blade not sure on the size, its a big 1 not a dinky 1 if that helps tel ya anythin lol but i wil say there is a similar fan in my other kitchen & u can feel the air just fine?? so i dnt no?
