Installing pendant lights?
Received 0 Votes
I did read the "How to" article, but it only dealt with installing new fixtures where old ones existed.
I removed a suspended kitchen cabinet and want two pendant lights installed. I need to know - is this a major, expensive job or a DIY project for someone who is handy?
There is an outlet on the wall behind the white microwave oven.
Here is where I want the lights to go :
It is possible as long as you are willing to patch some drywall. You will just need to find a source of power on a lighting circuit.
You cannot use the receptacles from the countertop or kitchen/dining room for your power source.
Received 0 Votes
Thank you....not something I would undertake then.
I know you cannot possibly tell me exactly what a job like this would cost, but is it possible to give a range of prices for this job....just ballpark?
There's attic space over the kitchen
If the track light does not have a always hot cable then it gets a bit more complicated but still doable. It may be better to use another source because you would probably need to remove the track light temporarily.
Depending on your roof line, this could be a "no wall repair" job. This would involve someone going into the attic.
My suggestion is to feed the pendants off the can/light above your sink. All the lights over the counter will then be on that one switch. If you did it like that I would ballpark the job at around $400US (I see you are from Canada). The cost/difficultly would go up if you wanted the pendants on their own switch. Prices vary a great deal so it could be more or less depending your area. If it cannot be done from the attic, some access holes might then need to be cut in the soffit and the wire fished through the soffit. However, the the light over the sink is a can, you might be able to remove the can to gain access to the soffit's inside.
Received 0 Votes
The pendants would be fine working on the same switch as the can light over the sink which has it's own switch.
Thanks so much for giving me some idea of cost. I know it can vary widely and I had no clue.
