ceiling fan
Old 09-06-09, 09:21 AM
R
ceiling fan
I have a hampton bay ceiling fan, which i installed using direct power. it has was working find for a few weeks, now it lacks power and the fan body is hot to the touch ?
Old 09-06-09, 02:13 PM
voltage at connection
there is no voltage at the connection, where you wired up the fan?
if it hot to the touch than it can be tat the motor is burnt out or if it has thermal switch, that burnt out.
Old 09-07-09, 06:49 AM
pcboss's Avatar
Received 200 Upvotes on 175 Posts
Have you dropped the canopy to check your wiring connections?
Turn the power off and see if the motor cools off.
