Ceiling Fan Lamp Kit Wiring Woes
Received 0 Votes
Purchased a lamp assembly for my existing ceiling fan. It currently has a 5 position power wall switch for the fan. The light assembly (from Lowe's), has the obligatory two wires (white & black), and is the screw-thru-the-center type. The insides of the existing ceiling fan assembly has two unused wires (white & blue), the blue wire has a 'Lights' label. There is also a block switch inside, with wires running from it to the forward/reverse switch...along with the fan on/off switch The wiring instructions with the light assembly say to connect the black to black (or blue) and the white to white...that doesn't work. All bulbs are new and the lamp switch seems to function. It seems obvious that I'm not getting power to the light assembly, but I don't see where else to tap it. Of course it could be the light assembly, but that seems less likely to me...something seems too easy with connecting two wires and having it work. I really don't want to replace the whole ceiling fan. looking for help/ideas. Thanks in advance.
snpperhd
snpperhd
Does the wall switch also have a light switch? If not, it may have been wired for the fan only without any power feed for the light connectors. If you wired the light kit to the fan feed, it would be controlled by the speed switch which would act as a dimmer.
You need to check the switch box for unused leads as a first step.
Received 0 Votes
Yes, it does have a light switch next to the dimmer switch. Currently that switch controls a wall outlet where I used to have a halogen floor lamp plugged in. So I need to look at the wiring behind that switch?
snpperhd
snpperhd
The insides of the existing ceiling fan assembly has two unused wires (white & blue), the blue wire has a 'Lights' label..... The wiring instructions with the light assembly say to connect the black to black (or blue) and the white to white...that doesn't work
Received 0 Votes
Okay, there's no spare wires in the ceiling fixture box, just the 9 wire plug; there are extra wires in the ceiling plug in relation to the lamp assembly. On the wall switch box, I see an extra red wire tucked away; seems like that wire needs to be connected. As I said before, the switch currently controls the wall outlet, should I swap the extra wire with the red wire in the wall on/off switch? If I do that, I assume the wall outlet would no longer work. I don't imagine I could add the red wire to the switch leaving the existing red wire connected, as the switch would control the light plus still control the wall switch. I'm sure I'm rambling, hopefully there's a clue in there somewhere. Thanks.
snpperhd
snpperhd
Received 0 Votes
Yeah, that's not a ceiling box, the ceiling fan hangs from a 3 foot pole from which there is a 9 pin connector. Above this is wiring which apparently runs to the switch. It has red, white, black & copper coming down...the black is connected to black, white to white, copper to green & red to blue of wires going down to the ceiling fan motor housing. Coming out of the bottom of that housing are the wires going to the 9 pin connector. Those wires are pink, purple, blue, white, red, gray, black, brown & yellow.
Received 0 Votes
I want to make the wall switch (currently controlling the switched outlet), control the ceiling fan light assembly and keep the fan on/off dimmer as is. The wall switch box has the power coming in (two wire romex), along with two seperate 3 wire romex controlling the wall outlet and ceiling fan.
You will need to remove the black to the receptacle and black from the power in from the switch. Connect the black of the receptacle, black of power in, and a 6" pigtail together. The red will go to one side of the switch and the pigtail to the other.
Do not disturb the white wires. Follow standard grounding procedures.
Received 0 Votes
I've got 3 wire groups in the wall switch box, one is the 2 wire romex carrying power. One 3 wire romex for the switched outlet, one 3 wire romex for the ceiling fan. All 3 whites are nutted together, all coppers are connected, the black from the power input and the black from the switched outlet are nutted together with pigtails going to the input of the wall on/off switch and one going to the fan dimmer switch. The red from the switched outlet is going to the top of the wall on/off switch and the black from the ceiling fan romex is going to the top of the dimmer. The red from the ceiling fan romex is unconnected. How will I provide on/off switch power for the ceiling fan lamp assembly and still allow the ceiling fan to turn on/off via the seperate dimmer? Also converting the switched outlet to a permanent hot outlet. My 1st thought is to replace the red of the ceiling romex with the red on the switch of the switched outlet and pigtail the black from the ceiling fan romex to black power in and connect to the switch, but wouldn't that provide constant power to the ceiling fan? Sorry for the length and confusion.
There is a second way to do this that involves that involves changes at the receptacle but I believe the way I have given is simplest.
If you have questions or need a diagram post back.
Received 0 Votes
Ray2047,
Based upon your help, I completed the job by swapping the red wires and replacing the tab removed wall receptacle. All works perfectly thanks to your patient help. Thanks again for your time.
snpperhd
snpperhd
