Best undercabinet lighting
Old 10-05-09, 04:46 AM
W
Could someone steer me in the right direction to some good under cabinet puck lighting. Probably want Xenon or LED and not halogen because of heat. Where can I find it? Thanks.
Old 10-05-09, 05:31 AM
pcboss's Avatar
Received 202 Upvotes on 176 Posts
Puck lighting is very uneven compared to the strip or linear style of lighting.
Are you looking for low voltage or line voltage? Do you have access to run wiring in the walls and a circuit, not the countertop circuit, to pull power from?
I normally install the Ambiance from Seagull, but just saw that Juno has a lot of new options including LED.
Old 10-05-09, 01:19 PM
W
I can run any kind there is. I will have all the cabinets down and the electricians can do what I need. Throw it at me. Low voltage or line voltage does not matter. Whatever you think is the best.
