Microwave and Range Hood circuit
Old 12-13-09, 11:43 AM
B
We are remodeling our kitchen and getting a bigger stove and new range hood.
I am removing the "over-the-range" microwave, installing a 42” chimney range hood and then buying a new "over-the-counter" microwave which will sit to the left of the range hood.
The current microwave has a dedicated plug which is in a perfect location for the range hood. Is it a problem to run the range hood and the microwave on the same circuit?
I would like take the outlet that old microwave plugged into and tap into it to add a second outlet. So the range hood and microwave will share the same circuit that was dedicated for the microwave.
The elementary way I see it is the over-the-range microwave has a built in fan. The new over-the-counter microwave does not, so what the heck?
Old 12-13-09, 12:12 PM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
If the range hood is cord and plug connected it will require a dedicated circuit under the 08 Code.
Do the instructions for the microwave call for a dedicated circuit?
Old 12-13-09, 12:38 PM
B
I'm not sure if the micowave says it needs a dedicated line or what.
Here are the electric specs:
Micorwave Sharp 1214 which draws 13 amps.
The range hood draws 230W.
Old 12-13-09, 01:45 PM
B
why would code required a 4 amp range hood to be on a dedicated line?
Old 12-13-09, 03:37 PM
pcboss's Avatar
The reason I was told was so that if anyone ever changed out the hood for a microhood the circuit would be adequate.
