cannot reset ceiling fan remote
Received 0 Votes
I've scoured forums and googled everything I can think of but haven't been able to resolve what I think is a simple issue.
We bought a condo with a ceiling fan, wired in to a contractor box with a light switch. A piece of tape said "Do not turn this off." A friend came over to help paint and of course flipped the switch, rendering the ceiling fan remote useless. It was working before the switch was flipped, so it seems safe to assume that the it is wired and configured properly.
There is no brand information and no manual, the receiver up in the fan reads "Ceiling Fan and Light Kit Remote Controller" and a model number RW111-1-4A, I googled both to no avail.
I can't locate the dip switch on the receiver, it's a completely generic black box with a single black switch. The dip switches in the remote were all set to on (all four are up).
I tried to power cycling the various components but have no idea about what order I should try. I'm guessing if I do it in the right sequence the remote will resync with the receiver. Any advice would be appreciated.
Thanks
Thanks
You failed to mention whether or not you turned the switch back on. Just turning it off won't affect the remote control, except to turn the power off to the fan. Once power is restored, the remote should operate the fan.
The dip switch on the fan should be under the canopy at the ceiling box. As you already know, they have to be set identically in order to work.
If you get the light try the pull chain for the fan. Pull once and try with the remote. Four maybe five tries should exhaust the possibilities.
Received 0 Votes
Thanks for the feedback. I swapped out the light switch because I thought that might be the problem and it didn't make a difference. There's no pull chain on the fan, it's kind of modern looking. The only switch on the fan is the reverse switch. The only other thing I can see is the unmarked black switch on the remote receiver. I haven't replaced the light bulb so I'll try that next.
The thing I'm most confused about is that the previous owner obviously knew that something would happen if the light switch was flipped, because he put the warning message on there. One question I have is, when I flip the circuit breaker, will that change which direction indicates "on" for the light switch? If I leave the switch on, then flip the circuit breaker, will the switch still be on or do I need to flip it to the down position? I've tried it in both directions but I just don't want to waste my time if I don't have to.
@chandler: What I mean is that there are several things that can be turned off and on. Namely the circuit breaker, the light switch representing power to the fan, the switch on the remote control receiver, the battery in the remote control. I was under the impression that if I turned everything off, then turned each item back on in a particular order, the remote would sync back up with the receiver, but Ray seemed to indicate this is not really the case. I thought this might be true because I had to resync my garage door remote, but again I gather from Ray that they probably don't function the same way.
Thanks again, I'll keep playing with it. I'm sure there's something fundamental I'm just missing
