Xenon under cabinet lighting
Old 02-02-10, 09:30 AM
I purchased some GE brand xenon under cabinet lights along with a junction box (GE part number 24772) required to hardwire the lights. I had an electrician run a separate wire that is connected to it's own light switch before I replaced the cabinets in my kitchen.
The problem I am having is that the junction box does not have a ground wire to connect to the existing ground in the romex even though the picture in the instructions shows a green wire. This is a three light fixture for a total of 60 watts. Does it need to be grounded and if not, what do I do with the copper ground found in the romex?
Thanks in advance.
Old 02-02-10, 12:09 PM
pcboss's Avatar
Received 16 Votes on 13 Posts
If there is a green screw or wire inside the junction box it would attach to the ground in the cable. There may be a mark like a christmas tree near this screw to indicate it is the ground. If there is no wire or screw just tuck the ground in the box. Do not cut it off.
Old 03-05-11, 12:02 AM
xenon and junction grounding
I bought the same setup, the junction box comes with a copper wire that gets attached to the bx cable and nut
