Recessed can light dimmer woes
Received 0 Votes
When I turned on my kitchen overhead lights this morning, I slid the dimmer to the high position as I always do, but when it got there, all the lights went really dim and began to flicker, almost like a bulb does when it's burning out. I slid down the fader a little and all was fine. So, I tried to turn them up full again, and the same problem occurred. Anyone have any ideas about what is causing this?
A friend mentioned the fact that it's been cold lately here in Florida and that might have something to do with it. I'm hoping that it's something that silly, but I have my doubts.
Thanks in advance.
Thanks in advance.
Received 0 Votes
How many lights on switch? How old is dimmer? These are rated for certain voltages if you overload them you can have issues. Sometimes reistat contacts on cheap dimmers can go bad too, I have a had several of mine give up the ghost.
The pros will have better answer those are just my personal experiences
Received 0 Votes
Thanks in advance.
Thanks in advance.
Received 0 Votes
Agreed
I agree. Dimmers can and do go bad. Just for convienence though. How many lights are on the dimmer and what watts are the bulbs. most dimmers are rated for 600 watts, even less if the tabs on the side of the dimmer are broken off. Just somethings to check, if your going over the rating of the dimmer you might want to get a 1000 watt rated dimmer (more money)
Received 0 Votes
Thanks for the input. There are 8 lights and they're 50 watt bulbs, so I wouldn't have thought the wattage thing would be an issue. I've had the dimmer in for about 7 years and never had a problem until now.
Would my best course of action be to buy a new dimmer to replace the old one? Assuming that it is, is it simple to do? (Bear in mind that my skill level is somewhere around that of Mr Bean)
Thanks again.
Thanks again.
It's probably not a fire hazard, just won't work right. Heed the advice to turn off the power before replacing the dimmer, that is not just safety advice. Installing a dimmer to hot conductors usually will damage the device.
