Fan attached to box ears?
Old 03-01-10, 09:43 AM
D
Hi all, this is my first post here.
Here is the situation: I have a metal non-fan-rated electrical box that I secured to the beams in my ceiling. I attached the box to the frame of the house, so the box is not going anywhere. I am just worried because the fan is attached to the electrical box ears, rather than the heavy-duty threads that you see in fan-rated boxes.
What do you think? Am I okay with a not-so-heavy fan attached to the box ears on a heavy-duty looking metal electrical box? The fan does not wobble or move or anything.
Your thoughts would be appreciated.
Eric
Old 03-01-10, 05:00 PM
mickblock's Avatar
You should install a box rated for use with a fan. The weight of the fan is not such a factor compared to the fact that it moves. And that is a huge factor.
If it's solid now, that will change over time.
How do I know? I've done it.
Wanna see the thread I got busted in?
http://forum.doityourself.com/lighti...een-beams.html
The answer I posted refers to a ceiling fan I had put up in my living room when I first bought my house.
After the next two responses I went in the living room and turned on the fan. It is in fact loose at the electrical box that I used. Turns out it is a regular electrical box and not the required fan rated box! This thing used to be steady as a rock.
Old 03-02-10, 08:35 AM
pcboss's Avatar
Received 141 Votes on 125 Posts
The box does not need to be fan-rated if it is not the sole support for the fan. Can you use long screws and attach the bracket to framing lumber behind the box?
You can also purchase old work fan-rated boxes for old work applications.
