Ceiling fixture near gas line
Old 03-28-10, 05:56 PM
I'm trying to find a lighting solution for my basement hallway.
I have a 1" gas pipe running the length of the hall, dead center.
The hall is not that wide, so I want to avoid wall lights. I planned on possible using 3 puck lights staggering the gas pipe on each side. Most likely using xenon lights, as I hear they give off less heat than halogen.
My question is there a required/recommended set back between the fixture and the pipe, based on the heat given out by the light? Based on a my setup it would only be a few inches from the gas line...
Old 03-28-10, 07:01 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
The code is silent. Use IC rated lights just to be extra safe.
