New Ballast Problems
Received 0 Votes
I just installed a new ballast for a 1-2 lamp flourescent. It appears to work initially providing electricity to the bulb and after about 2 seconds it goes out. I can turn the switch of and then on and it happens again. Any thoughts. Would appreciate it.
Received 0 Votes
Everything is correct.I just installed another ballast in the same building and it is working fine. Same type of bulbs and ballast. Im not sure why this one just goes on for 2 seconds and then shuts off. Before I replaced the Ballast it did nothing.
It is possible to buy a brand new product that is defective. Since you have more then one fixture swap with a known good ballast. Have you checked there is no accidental short, that the wire nuts are good, and the wires to the tombstones solid?
Can you run the ballast model numbers if possible ?
The reason why I am supecting something is not right due some ballast is very sestive with grounding and the starting producures.
Merci,Marc
Merci,Marc
