Dimmer on exhaust Fan?
Old 07-05-10, 06:04 PM
C
Can I install a normal dimmer switch that will be connected to a bathroom exhaust fan?
Currently I have the exhaust fan in a small fermentation room with the usual on/off switch. I want to slow down the rate of exhaust. I'm hoping this will do the trick rather than purchasing a slower less-powerful fan.
Thanks
Old 07-05-10, 06:09 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Welcome to the forums! A "dimmer" in the oldest sense...no. Check the various sites, such as Leviton, Pass Seymour and others to see if they have a fan rated dimmer that will handle the load of your fan.
Old 07-05-10, 07:25 PM
Tolyn Ironhand's Avatar
Received 551 Votes on 473 Posts
Broan, and other fan manufactures I'm sure, make speed controls designed to control fans. They work quite well. A standard dimmer will either burn out the dimmer or burn out the fan rather quickly. They will also not have much range on them.
