Replace two 2bulb ballast with 1 four bulb ?
Received 0 Votes
Can this be done. I have a 4 bulb ballast, but took off the ballast covering on the light to find 2 two bulb ballasts. Can i just use the 1 4 bulb ballast?
What model number 4 lamp ballast you have there ?? if you going to 4 lamp ballast you have to follow the wiring diagram carefully and for sure I know from my past experince you will denfity for sure get T-8 bulbs as well.
Merci.
Marc
Merci.
Marc
